Did the finger in the spark plug hole and it does push air in and out. I got the mower from a guy who said it he went out to fire it up and it just wouldn't start, he said it ran til he shut it off before that. I took the carb off cleaned it out down to the float, pulled and regapped plugs, sanded and re gaged the coils, made sure oil was good it's pretty much brand new, fresh gas and filter, he had a few wires on the harness that were twist tied and electric taped. I don't like that so I butt connected them all. It has spark, airflow, fuel flow, and as far as I can tell it has compression. I just don't know if that oil coming from my exhast might be loosing enough compression or putting oil into the compression chamber which won't let it ignite. One other thing when it turns over I get no smoke from the exhaust at all which leads me to believe that the mixture isn't combusting at all.
