SnapperOwner
Just took photos of the breather assembly opened up. Doesn't look like the parts diagram. There's only the one piece (with the two screws) that's slightly bent up, but the parts diagram shows a solid piece under that one. The diagram sometimes has errors, but I can't find anywhere online that shows you the parts to this. Also, what is that black plastic circular piece that you can see through the hole?
Sorry for the stupid questions. I've been told by two people that Vanguards rarely blow their head gaskets (as opposed to Inteks), so I should go back to looking at that breather assembly again.
Everything look all right here to those of you familiar with Vanguards?
