junkman108
- Apr 11, 2018
- 41
I don't think that crankshaft will clean up without turning under size.
"Also the condition of the camshaft bearing surfaces in the engine. I suspect that they are also damaged."
I suspect the camshaft bearing bosses are cracked.
Walt Conner
they used to make a .020" under size but it is obsolete. If the cranks is cut wouldn't the connecting rods have to be oversizex not undersized ?? Or do they just call it undersized because crank journal is undersized? These engine don't use rod bearings.
