Briggs & Stratton XR1450 Magneto testing
chadh
Have a Briggs & Stratton XR1450 (19N137-0084-F1). No spark when the ground wire is disconnected. Does anyone have shop manual or the specs for the resistance for primary and secondary coils?
Thank You
Chad
There are no specs or procedure for testing todays magnetos. You preformed the test used by 99% of all service technicians when you disconnected the kill wire and checked for spark. From your results time to replace the magneto.
It is a magneto coil
It is not repairable
