jono252525
I am rebuilding this B&S snowblower engine that blow the connecting rod and scratched the cylinder and the piston also.
The spec say Bore Diameter 3.300 in. (83.82 mm) Reject at 3.304 in. (8)3.92 mm.
I was able to hone the cylinder and removed the scratch but now I am at 3.304 in.
Could I get away by replacing the piston by the standard size ?
The problem is that the other option was a .020 over size piston that is NLA.
I would prefer a .010 over size piston, but no information from B&S on that option.
I cannot find an other company that would make a compatible piston for my engine.
Here the spec of the engine.
B&S engine 21M314-2470-E2 ,spec
The Briggs & Stratton engine model 21M314-2470-E2 is a 342cc Snow Professional Series
horizontal shaft engine designed specifically for snowblowers
Number ingrave in the Standard size piston = H079A 5 216413 Or B&S 793318 or 791813
B&S oversize piston .020 inch Number 793325 but NLA
And No information on a .010 inch oversize piston ( option )
Engine specifications
Other features
The engine 21M314-2470-E2 refers to a Briggs & Stratton 1650 Professional Series™ Snow engine, a 342cc, overhead valve (OHV), horizontal crankshaft engine designed for 2-stage snowblowers, producing 16.50 ft-lbs of torque, with features like a float-feed carburetor, Magnetron® electronic ignition, and a freeze-start primer for cold weather operation
I need your help to find a .010 oversize compatible piston. OR ?
- Engine Series: Snow Professional Series
- Engine Type: 4-cycle, single cylinder, air-cooled, Overhead Valve (OHV)
- Displacement: 342 cc
- Torque: 16.50 ft-lbs gross torque
- Cylinder Bore: Aluminum alloy
- Bore and Stroke: 79.0 x 61.0 mm (3.12 x 2.43 inches)
- Lubrication: Splash lubrication system
- Oil Capacity: 26 to 28 ounces (0.77–0.83 L)
- Fuel Tank Capacity: 3.03 L (3.2 quarts)
- Crankshaft and starting system
- Crankshaft: 3/4-inch diameter, 2-33/64 inches long, straight shaft with a keyway.
- Starter: 110-volt electric starter with a recoil (pull) starter backup.
- Alternator: 60-watt AC alternator.
- Features for cold weather starting
- Easy-start primer
Other features
- Ignition: Maintenance-free Magnetron electronic ignition.
- Carburetor: Float carburetor for reliable fuel delivery.
- Governor: Mechanical.
- Exhaust: Super Lo-Tone muffler for quieter operation.
- Controls: Manual friction/remote control and manual choke.
