- May 6, 2010
- 12,045
Couple of things that could of occurred. First the float valve may not be sealing. And 2nd that style of carb has a removable plastic insert for lack of better term which has an O ring that seals the fuel inlet as the fuel enters the float seat area. If that O ring came out or is torn it will allow the fuel to leak even before it enters the float valve seat area.
Also need to sure the jet doesn't fall out of the end of the plastic emulsion tube if removed from the carb. Also some of those carbs have a spring in the bottom of the fuel bowl to maintain upward pressure on the plastic emulsion tube mushroom top to seal the gasket and fuel inlet O ring to the carb body.
