This may be a stretch but I'm hoping someone can offer some advice.
Last summer, my 17 year old son used my roughly 8 year old Model No. 580.752050 Craftsman power washer for several jobs as he went about making money. I regularly asked him to stay on top of the oil situation. I know he didn't do a great job because one time when I checked the oil was a goopy grey mess. I learned online that throwing some diesel in with the goopy oil can loosen it up and I was able to clean it out and get new oil in there. At that point I didn't look further for how the oil got that bad. I figured it was simple misuse over a long period of time.
A buddy used the power washer this year as he cleaned up his house to sell. Upon return, I noticed that oil was leaking all over the place, so I went about troubleshooting the problem.
I pulled it apart looking for the source of the oil leak which was presenting all over the place and resulting in oil dripping down off the engine onto the power washer frame and onto the ground. I replaced the head gasket and that didn't help enough. I would start up the engine but it would still leak. I realized it might be the shaft seals but had a gasket replacement kit and decided to replace the remaining gaskets first and go from there.
I also pulled the pump assembly off the bottom looking for leaks and then put it back together.
The power washer started right up but I wasn't getting any pressure beyond what came through the garden hose. I later diagnosed that I missed that the key fell off the crankshaft and without it the crankshaft spun but didn't drive the water pump assembly. Suffice it to say that there was some metal paste where the metal shaft rubbed again the slotted metal receiver.
When I put the key back in place, the engine started up, water pressure built up for maybe 5 seconds and then the entire engine died and wouldn't restart.
I figured that with the carb taken off (and the gas tank) to replace gaskets, I must have dislodged some crud and gummed up the jets and the engine was fuel starved. It turned out the float bowl was full of sediment and half the float bowl gasket cracked and fell apart. And the float was heavily varnished.
So, I bought a new carb and replaced it this morning. I got everything together, crossed my fingers, and pulled. And pulled. And pulled some more.
The engine wouldn't start even as it felt like it had good compression. And I confirmed there is a spark.
Of note, I did notice that as I repeatedly tried to start the engine water pressure would build in the wand. And the pulling would get progressively harder. The fourth pull would be the hardest. The next one would be much easier and the sixth pull would get the closest to starting with the right amount of blueish smoke coming out of the exhaust, but it just wouldn't turn over.
Not sure if this has any baring on my starting problem or not, but I had played with the unloader valve when I mistakenly didn't have the crankshaft key in place and was solving for lack of pressure.
Does anyone have any idea what I should check next? I like solving puzzles, but this one might drive me to an early grave!
Thanks in advance for any and all advice.
-Trevor in Austin
-Trevor in Austin
