motor runs wide open when starts
R richardgarner@embarqmail. Forum Newbie Joined Dec 22, 2014 Threads 1 Messages 2 Dec 22, 2014 / briggs & stratton 5.25 carbuertor adjustment #1 motor runs wide open when starts
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 176 Messages 7,495 Dec 22, 2014 / briggs & stratton 5.25 carbuertor adjustment #2 Post model xxxxxx, type xxxx, trim xx from engine, thanks.
R richardgarner@embarqmail. Forum Newbie Joined Dec 22, 2014 Threads 1 Messages 2 Dec 23, 2014 / briggs & stratton 5.25 carbuertor adjustment #3 mechanic mark said: Post model xxxxxx, type xxxx, trim xx from engine, thanks. Click to expand... model 094352 type0121 trimB1
ILENGINE Lawn Royalty Joined May 6, 2010 Threads 51 Messages 11,396 Dec 23, 2014 / briggs & stratton 5.25 carbuertor adjustment #4 Don't know if this will help but I have had cases where fuel varnish would stick the throttle butterfly in the carb, in the full throttle position. Make sure the throttle is moving freely by hand.
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 176 Messages 7,495 Dec 23, 2014 / briggs & stratton 5.25 carbuertor adjustment #5 Results your engine operators manual & illustrated parts list. FAQ | Lawn Mower Safety Tips | Briggs & Stratton check throttle cable and carburetor linkage operation, you may need to lube cable & linkage with lubricating oil.
