R richardgarner@embarqmail. Forum Newbie Joined Dec 22, 2014 Messages 2 Dec 22, 2014 #1 motor runs wide open when starts
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,499 Dec 22, 2014 #2 Post model xxxxxx, type xxxx, trim xx from engine, thanks.
R richardgarner@embarqmail. Forum Newbie Joined Dec 22, 2014 Messages 2 Dec 23, 2014 #3 mechanic mark said: Post model xxxxxx, type xxxx, trim xx from engine, thanks. Click to expand... model 094352 type0121 trimB1
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 11,985 Dec 23, 2014 #4 Don't know if this will help but I have had cases where fuel varnish would stick the throttle butterfly in the carb, in the full throttle position. Make sure the throttle is moving freely by hand.
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,499 Dec 23, 2014 #5 Results your engine operators manual & illustrated parts list. FAQ | Lawn Mower Safety Tips | Briggs & Stratton check throttle cable and carburetor linkage operation, you may need to lube cable & linkage with lubricating oil.
