I had a no start issue with the Twin 2 after it was up to running temperure after mowing for a half hour or so. It looked to me that the spark wasn't as hot as I thought it should be,as no spark that I could see. After it cooled overnight it fired right up,no problem. I mowed a bit and restarted it several times with no issues,started every time. I think this is a 1995 engine according to the ID tag. I am wondering if there is a upgrade hotter magneto for this engine. I know there is a ton of good knowledge here,so this is the best place to ask. TIA!I've have a 422707 on my GT. '89 year. Keeps on chugging. A little fuel thirsty. You do have to re-build the fuel pump on carb every 3-4 years. But now - they have AM carbs for ~$30. I'd get another Opp Twin in a heartbeat.
Were you using 10w40?As I said in the previous post,2 different Intek AVS 17.5 singles have failed me,or should I broke themselves(and me,too)!
a couple of years ago,the first one ,for no good reason,snapped the head off a valve right above the stem and the head punched right through the piston. I bought a new Intek 17.5 AVS and put it on the Snapper 33" Extra Tough.
The second Intek 17.5,on my Husqvarna Z42175 zero turn,starting making unnatural rattling noises(death rattle?) so I shut it down,checked the oil. That was OK,so as I was in the far side of the yard,I started it back up and the rattle was back with a vengeance. I quickly shut it down again and towed it to the garage and removed the engine. When I removed the sump part of the case I saw one of the arms that move the AVS weights had broken. Since I mow a much larger area with the zero turn,the almost new Intek got transplanted to the zero turn and the Snapper got parked,engine-less. Till now.
Both of these engines were well maintained,regular oil and air filter changes,using good oil and having never messing with the governor,ran at the factory rpm settings. Both times,the engines were running just as fine as could be....till they instantly weren't.
There's not a hotter coil other than an OEM briggs coil, a old coil or a coil that's got one foot in the grave and a the other on a banana peel can get weak when it heats up.I had a no start issue with the Twin 2 after it was up to running temperure after mowing for a half hour or so. It looked to me that the spark wasn't as hot as I thought it should be,as no spark that I could see. After it cooled overnight it fired right up,no problem. I mowed a bit and restarted it several times with no issues,started every time. I think this is a 1995 engine according to the ID tag. I am wondering if there is a upgrade hotter magneto for this engine. I know there is a ton of good knowledge here,so this is the best place to ask. TIA!
No,Shell Rotella straight 30WWere you using 10w40?
That is good info for me. I see on Amazon,they have the 590781 coil listed for a 42A 707,which is what I have. $15.00. Not a bad price,but a bit of a job getting to on this engine. Briggs didn't skimp on shrouding or number of bolts holding them on on this engine!There's not a hotter coil other than an OEM briggs coil, a old coil or a coil that's got one foot in the grave and a the other on a banana peel can get weak when it heats up.
Briggs 394891 (superseded TO 590781) is the magnetron coil, meaning for the twins without points.
Follow-up on the weak spark/coil issue. I got the new coil from Amazon,put it on and the engine fired right up,sounding better than it ever has.That is good info for me. I see on Amazon,they have the 590781 coil listed for a 42A 707,which is what I have. $15.00. Not a bad price,but a bit of a job getting to on this engine. Briggs didn't skimp on shrouding or number of bolts holding them on on this engine!
Well,the old 18hp twin just wasn't cutting it this Spring,(sorry for the pun and I could see one side of the exhaust wasn't getting as hot as the other side Shorting out the 'good' side spark plug almost let the engine die. Doing the same on the 'bad' side had no effect on the rpms. Swapping sides with the plug wires changed nothing. I didn't have time to really get deep into just what the problem was,so off it came and a brand new 500cc single went back on in it's place. I'll get deeper into what the issue may be with it,but for now,it's back on the shelf and declared surplus!Thanks for all the positive comments on the Briggs opposed 2 cylinder engine. I really wasn't wanting to spend major money on another Intek engine that seems to have inherent reliability issues. I know,I know,there are those that will sing their praises. That's ok with me,but I have had 2 that ,for no apparent reason,self-destructed,so I am perhaps a bit gun-shy.
After a few hours of planning,fitting,bolting down and wiring,the Snapper mows again! I'm working on actual muffler mounts,coming off the rear,but(shame,shame) bailing wire is working real good right now! :-D
The I/C 18hp opposed is so much smoother and quieter than the Intek single,it's amazing. Like I said,thanks for the encouragement to do this. After all, I had the engine to begin with,so no real loss but time. Since I'm retired,no issue there either.
