Hello all,
I have a Husqvarna c42175 zero turn mower with a 17.5 Briggs Intek AVS single cylinder engine on it. It's a 2005 and the engine runs fine but is beginning to smoke a bit and it has a lot of hours on it. I have 18hp Briggs I/C opposed 2 cylinder from a previous lawn tractor type mower. It ran smooth and quiet and started easily.
I only used the mower it was on a couple of times as the deck cracked and wasn't safe to continue to use. Scrapped it and kept the engine. My questions are,is this a good long term engine as far as reliability and holding up over time? Is it worth the time to fit it on the zero turn? Looks to be an easy conversion,one electtric clutch on the crank and throttle,wiring,etc should be no real problem. I'd have to make other provisions for the exhaust because the original muffler was under the 'chin' of the tractor.
