- Nov 29, 2014
- Threads
- 64
- 24,729
IF the fuel is dripping back out of the carb then it would normally be a float problem but as this is a tank mounted carb with an overflow bowl that can't happen.
So something is causing blow back through the carb
Two sources of blow back at cranking speeds
1) breather
2) valves out of adjustment / time
On side valves it would normally be something preventing the inlet closing or the exhaust opening
Exhaust opening includes furry things dead in the muffler blocking it off .
On OHV engines it is generally excessive exhaust valve lash causing excessive valve overlap .
1) breather
