I have a Scotts S2546 mower with the B&S 25HP V-twin Intek... It was running fine one day, then the next it was running on one cylinder. Found no compression on the bad cylinder, pulled the valve cover to find the intake push-rod bent and floating around in there.
Now I can replace the push-rod for only about $6 but I'd like to know WHY it bent in the first place. Any ideas? Just a bad rod or...?? The exhaust rod looks OK. I can push the intake valve open by hand no problem.
It's weird that this seemed to happen when the motor was "off". So it bent when stopping the motor or trying to start or something? Maybe it ran fine with the bent rod until finally it popped out? So weird.
Edit:
Honestly I can't remember if I've ever checked the valve lash since owning this (maybe 5 years). I'm thinking maybe the valve clearance was way off. Either way too tight or loose which then caused the rod to bend somehow. I don't know. Will be checking the other (working) side soon to see how it's doing.
Edit:
