Briggs Intake Manifold Gasket
depawl52
Greetings. I'm changing the carburetor on my 23 HP Briggs V Twin on my JD Zero Turn. The new carb comes with gaskets, which include gaskets for the intake manifold (see attached), which are different than what I found when I removed the carb (O Rings).
So, when installing the new carb, should I remove the existing O Rings (even if they appear to be in good shape), and install the new gaskets, or install the new gaskets over the existing O Rings, or just do nothing and reinstall the manifolds and leave the existing O Rings untouched?
Anyone know why the O Rings supplied with the carb are different than the original?
Thanks.
If the existing O rings are in good shape then reinstall them. Don't remove and use the other gaskets or try to put the gaskets over the O rings. The plastic intake that is used with the O rings is not rigid enough to properly torque a normal gasket. And could create an air leak at the junction.
Thanks ILEngine. That's kind of what I was thinking. Makes one wonder why they even include the gaskets with the carburetor.
I take little bit of extra care in this area especially if the engine has a surging and hunting issue. (and a dreaded Nikki carb)
I use the gasket over the o-rings, but I've also used the gasket W/O the o-rings. If I have no new flat gaskets available I make the manifold gaskets myself. I trust the gaskets with the Permatex more than I do using the old or even new o-rings.
I always use a light smear of permatex gasket maker on each side of the gasket when re-installing.
If you look at the plastic manifolds they have a steel collar insert through the mounting holes that limits the amount of plastic compression to the manifold seal and can result in leakage when re-using old o-rings. If too thick of a gasket is used it's possible that the plastic ear on the manifold might crack when installing.
I haven't seen any crack from people trying to use the paper gaskets, but I have seen them warped at the mounting flanges so bad that the O ring won't even make contact with the head mounting surface after somebody tried to use the paper gaskets, and the mounting ears compress into the paper.
Over the years, I have seen many intakes distorted from overtightening of the mount bolts. These bolts only require light torque and most are installed with a light-duty Loctite compound to prevent them from backing off.
I have saved a few by just filing down the mounting face lightly, some where just too far gone and had to be replaced with a new one or a good used one.
If I have new gaskets, I use them in conjunction with the existing O-rings and have had no issues. The O-rings have been previously crushed and distorted, so it does little good to rely on them to reseal properly. In the event I don't have new gaskets or new O-ring seals, I use the brown Permatex gasket maker paste and it seals them up nicely. Permatex Aviation sealer also works really well if used sparingly.
There is no reason to ever use an excessive amount of any gasket sealer, just a very thin layer will do.
Well the round orange or black seals are used with plastic intake manifolds and the cardboard / paper type are used with metal type intakes. Best to get new rubber o rings at local mower shop. If reusing them use a tiny amount of silicone sealer. Just a little.
