Greetings. I'm changing the carburetor on my 23 HP Briggs V Twin on my JD Zero Turn. The new carb comes with gaskets, which include gaskets for the intake manifold (see attached), which are different than what I found when I removed the carb (O Rings).
So, when installing the new carb, should I remove the existing O Rings (even if they appear to be in good shape), and install the new gaskets, or install the new gaskets over the existing O Rings, or just do nothing and reinstall the manifolds and leave the existing O Rings untouched?
Anyone know why the O Rings supplied with the carb are different than the original?
Thanks.
Thanks.
