Briggs & Stratton Model Number: 123K02-0258-E1 03012456
Craftsman 6.5 HP Self Propelled Mower Model Number: 917.377660
I have tried absolutely everything to get this mower started, and it will not start. This mower belongs to my mom and hasn't ran in two to three years. I knew the carb would be varnished and gummed up. I performed the following before attempting to start the engine:
1. I cleaned and rebuilt the carburetor, including cleaning all the ports and blowing them out with air; replaced the welch plug; the float needle and seat; the float bowl gasket and the air filter housing gasket; fuel hose; and tested the float seat by both blowing and sucking on the fuel inlet nipple to make sure it was seating. Please note, this carburetor does not have any adjustment possible... no fuel mixture or idle screws... no choke... the only moving part is a throttle plate.
2. I cleaned the mower and engine thoroughly from top to bottom, inside and out.
3. Changed the engine oil.
4. Removed and cleaned the gas tank, inside and out. I blew it out with compressed air and made certain it was clean.
5. Found the flywheel key sheared; removed, cleaned and replaced with new aluminum key.
6. Set the coil air gap to .006" (Spec is 6 - 10 thousandths).
7. Replaced the spark plug (three times). Checked the coil lead for cracks or damage. Checked and cleaned the kill switch wiring and switch.
8. Checked the cylinder compression and found it to be at 55 psi and holding.
9. Replaced the air filter and primer bulb.
10. I checked the spark and had a nice blue spark.
11. Filled the tank with fresh premium gasoline.
I tried starting it with starting fluid, carburetor cleaner, and WD40 with no luck. Then, I finally managed to get it running once by squirting brake cleaner in the spark plug hole and it ran perfect. After shutting it off, it wouldn't start again even with the brake cleaner. I tried squirting the fluids in both the carb and the spark plug hole. I tried using a known good spark plug out of another mower and three other brand new plugs with no luck. Finally, one more time it started, but only for a few seconds and then it quit again, not to be re-started. I pull and pull on the rope to start the engine, and it doesn't even seem like it's trying. I am so frustrated with this thing I can hardly stand it. I am a mechanic by trade and can't believe this this is kicking my butt! I am desperate for an answer... please help.
