TylerFrankel
- Feb 25, 2018
- 27
Ok ........... I'm back......... Scott and IL Engine gave you good advice........
Yes the magnets on your flywheel will work with the newer style Mag coils.......... I do it all the time.....
As for as the two wires on the old coil, one is a kill and the other goes to the points and condenser for spark....... If you put the mag coil on there those point wires can be clipped... Like Scott said, no need to pull the flywheel.........
Plus Tard Mon Ami ~!~!
Thanks everyone! I looked at it today more when I got home and found out it's a 1976 model! One of the other 4 I got had the modern electronic ignition, so I pulled it and after ensuring that it fit I began reassembling what I disassembled. I checked the valves to make sure they weren't loose in closed position to make sure I wouldn't have problems later, and they seemed tight. Then, I tried to clear out the oil and water from the sump as best I could being that I could only pull the thing off 1/2 an inch. Then, I re-bolted the base on with 3 screws. I then put the bolts back on the bottom of the head and head gasket (5 big screws). Then I replaced the muffler and carb/gas tank (1 screw). Next I put the coil and pneumatic governor back (2 small screws). Then the top went back on (3 medium screws), and the throttle (3 big screws that go into head too, 1 small 1 on tank. After I did all this, I realised the engine won't turn anymore, and I was left with 3 small screws same size as the one that screws onto the gas tank. I probably just missed something somewhere or put screws in the wrong spots, but everything went in flush so I'm baffled, but I'll tear it back down tomorrow. If anyone knows where they could go let me know please. I don't think I put the bottom on wrong because as far as I know the parts inside line up as the screws that hold it in do, and it turned after that before I completely reassembled it. Anyway.... I couldn't check for spark but tomorrow I'll be home before dark so I can work for longer and re-disassemble and assemble to let the engine spin again and figure out where the screws go,then check for spark again. After that, I plan to drill some holes into wood to make a stand and try to fire it with some gas and see what happens. Provided that fails, I'll rebuild the carb and check again. After that.... I'll be out of ideas.
I'll make sure to give it throttle when I'm trying to start of course, and I don't imagine the coil will not produce a spark because of a kill switch if nothing touches the tab right?
On an unrelated note, I have a briggs from 85 with a magnetron and manual start system 2 thats mounted on a deck and it works but I can't for the life of me figure out how everything works. It has a manual throttle control, it appears the kill switch connects to the deck, and theres wires running everywhere that none of the other engines I have possess. The motor adjusts the butterfly and speed under load, but there is no vane/pneumatic system. it also has a brake, whereas these engines don't. I wonder if the previous owner removed some of these parts...? and if they won't work because they don't have a kill system?
Again I really appreciate everyones ideas!
