briggs and stratton .....
themowerking20
Time for me to go to a fall update.....6 years experience .....never seen anything like this
reynoldston
From the picture it looks like a clear plastic carburetor. Would like more info? What is it for? replacement? Would like to hear the story behind the pictures.
themowerking20
Definitely a clear plastic carb....will update when i do some more digging .....like i said 6 years as a small engine tech and never seen this carb
reynoldston
More is made from plastic all the time. I see the newer carburetors now have a lot of plastic parts now. What country was it made?
Mad Mackie
Don't overtighten any screws or nuts!!!
GetTechnicalWithJd
This is fitted to the new 9P series engines. Shear brilliance!
One thing about it, if you have one come in running poorly, you will be able to see where the problem is.
themowerking20
This carb goes on the newer briggs 5.50 ohv engine commonly found on walk mowers and pressure washers .....briggs made this one clear for demonstration purposes...
