I recently bought a 14hp V twin Briggs engine that originally came out of a Cub Cadet, model unknown, and I am putting it into my Snapper rear rider, more work than I thought it was going to be but love the challenge. The model# of the Briggs is 294777, type 0035-01. I need to know what the wires are for that stick out of this engine so I can make the proper connections for the new install.
#2
Fish
The wiring of any briggs is determined by the size Alt/magnets/regulator.
So you need to describe the regulator, color of wires, etc.
Fish thanks for the info. Tried to print out but only got the left side of the page any ideas how to do this. Can do it off the computer screen but not handy when in my shop
You will need to connect to a wire that is hot when the key is on and in the crank position, and not hot when the key is off, or you could just dis-able the solenoid.
Trying to up load a picture of my solenoid hope it works. Put new plugs in, carb kit, cleaned carb in tank with cleaner. Engine will run if I feed gas through the carb but will not continue to run. Seems to enough fuel getting to the carb. The fuel pump works. Have tried with the solenoid hooked up and with out hooking up. If I feed fuel through the carb the engine runs both ways, hooked and unhooked. At a loss gas does not seem to be getting through the carb.
EngineMan
Have you tested the solenoid off the engine yet, is it working..?
Is the solenoid tested with a volt meter, or an ohm meter? if so what should the readings be?
#23
Fish
No it appears to be a Vanguard, and his engine has jets incorporated with his solenoid, and the replacement is $85 or so.
So we need to verify that this part is his problem.....
#24
edgenet
test test test
#25
Fish
Just to know if the solenoid works or not, put the solenoid back on the carb, and set it up to run again. Run a wire from the solenoid to the positive battery terminal, and try to start.
I have done this. The only way it runs is if I feed gas through the carb. Do not hear or feel a click when hooked up. Will have to look at replacing and try that.
