Briggs and Stratton V twin electric info needed
wmg2
I recently bought a 14hp V twin Briggs engine that originally came out of a Cub Cadet, model unknown, and I am putting it into my Snapper rear rider, more work than I thought it was going to be but love the challenge. The model# of the Briggs is 294777, type 0035-01. I need to know what the wires are for that stick out of this engine so I can make the proper connections for the new install.
When you say "stick out of this engine" do you mean the yellow one's from under the flywheel..?
I will take a picture later this morning and see if I can figure out how to post it and show what I mean
Trying to upload picture hope it comes through, need to know which of these wires is for.
Thanks for the info. Going from a single cyl. B&S to this engine what wire would be hooked up to the anti after fire solenoid?
You will need to connect to a wire that is hot when the key is on and in the crank position, and not hot when the key is off, or you could just dis-able the solenoid.
