- Nov 29, 2014
- 64
- 24,705
Before this gets into a very personal slanging match Ohio Bob, you have to realize we have nothing to go on but what you have typed and have no idea of your technical understanding or abilitiesYou act like I don't know how to clean the carb adj valves I know it can be done incorrectly but what gives you the right to say I don't know what I'm doing. Like I said if you are so good you would give advice not sarcasm and put people down without even knowing them
We have had people tell us the they cleaned the carb when all they did was to spray the outside with throttle body cleaner and a bristle brush
Others will have "pulled tit apart & cleaned it" which ended up being dropping the float bowl & tossing out the bad fuel .
And most people will consider a carb clean if they poke the straw into every hole an some goop comes out some where else .
So the assumption is always the poster has no idea what they are doing till it is confirmed otherwise which is why I put the reference to the Outdoor Power Info page in post # 9 so you would know what we consider to be a properly cleaned carb.
I also asked you to do another test in post # 9
The way I work here, is I ask people to do things that all of the posters should be able to follow as we rule a cause in or out.
Normally there is nothing further from me til the question I posed has been answered or the test done & results posted .
In reply # 6 I explained what was happening and then proceeded to start to diagnose the reason for it .
No one here is deliberately trying to make you look stupid we are here to help you get your mower fixed .
