benson1980
- Apr 14, 2023
- 15
Hi all,
I am attempting a repair on my Makita lawnmower which has a B+S 675Exi engine. I believe that the flywheel key is the culprit for difficult starting/rough running and therefore have taken it apart to access it.
I have bought the special (and very expensive) tool that supposedly both acts as the flywheel puller, and holds it in place to remove the bolt. I have tried the strap wrench method and as you can see this has just caused the fins to shear off as I tightened around them. I have therefore bought a replacement secondhand flywheel off Ebay. This repair is not going well...
Now that I thought I had the right tools, I cannot for the life of me work out how the tool works to hold the flywheel securely in place whilst I remove the nut. The bolts just drop down loosely into the two holes. They don't actually secure into anything underneath. The instructions say hold the bolt in place with a wrench, but I'm just holding onto a loose bolt!
Is anyone able to tell me what I'm missing, or best way of holding the flywheel in place? My other issue appears to be that my blade rotates around the spindle freely so I can't jam it from underneath. Was going to try and fix that after I've sorted this problem.
Thanks
Thanks
