Damaged Briggs & Stratton flywheel
My son is rebuilding a Briggs and Stratton 3 HP (horizaontal shaft) engine as his HS Senior Project. While trying to remove the flywheel, I broke off one of the small fins (it's a flywheel / blower cast unit).  As a project only, and not for continued use, I'm wondering what the result will be if it is reassembled with that flywheel.  I assume it will vibrate more than normal, and perhaps the bearing surfaces will get more abuse, but I'm thinking it will run and be fine to demonstrate that he has learned how to disassemble and reassemble a working small engine.
Any comments?
Thanks,
Larry
