Briggs and Stratton engine won't stop
Scrubcadet10
Moderator
Staff member
Just take off the top starter cover and look. Follow the little wire to the kill switch connection. Probably needs cleaned out up there anyway.
x2
kyle1234
The throttle down on the engine, at the other end of that cable The part that you pictured earlier. Where it's in the fully closed position look for a contact.
Ha - of course, silly me. I'll take a look.
Fish
Likely just a kill mechanism on the blade brake device.
I actually have seen the switch to be used in both places and wired so. Just depends what the OEM of the equipment desired. Personally on a throttle controlled unit it makes sense to have it in both places and wired.
Fish
Yeah, it usually comes with both from the factory, so the engine can be used in all applications.
kyle1234
What seems to have happened, was the the throttle cable had been bent, meaning it had a kink in it, essentially making it shorter. This meant when the throttle was closed on the mower, it was not far enough round to make contact with the earth tag.
A few adjustments to ensure it would make contact with the earth tag fixed it. Have attached a pic of roughly where the earth tag is, in case someone else comes across this issue
