povertyacresmike
- Mar 14, 2016
- 1
- 5
Trying to figure out if I need to replace this carb. I believe the gas was bad when last used. I disassembled it, diaphram is ok, cleared the screen and pick up tube but when I reinstall the pick up, I cannot blow air thru it. The primer bulb also stays stuck in when priming the gas. Is there something between the bulb and the tube that can be cleared or do I need to replace the carb?
