Briggs and Stratton alternate motor for Agrifab Lawn Vac
1bbford
  • / Briggs and Stratton alternate motor for Agrifab Lawn Vac
Crankshaft don't normally break. It is the piston connecting that tends to break from lack of oiling. When this happens there is lot aluminum transfer to crankshaft rod journal. This simply removed using Muriatic Acid.
Now I would suggest a disassembly and check for damages and if no major damage then clean the crankshaft and replace the broken rod and other parts.
Now the replacement engine was the 12S402-0028-F8 which has been superseded to 15T212-0008-F8.
Well, it was the crank that broke. I'm guessing it let go when it was shut down. There is no other damage; it looks like the only metal (no aluminum) in the case is from pulling the cord.
Weld it back on.
Clean the weld area. Grind away to clean fresh metal. Have it TIG or MIG'ed up. Grind away any welding slag and polish her up. Lots of tacks to control metal warpage. Good welder can fix this. This is a low RPM mower type engine.
Reinstall it. Rotate it in some lube checking for out of roundness with a dial indicator. All of this is way cheaper than some $500 replacement.
Take it to your local vo-tech or high school welding class. Probably get it done for free. Worth a free phone call or two.
