- Nov 29, 2014
- Threads
- 64
- 24,742
I've just joined up to add to this thread.
Old Sanli mower, with exactly the same symptoms. Starts on full choke, revs, then dies.
Have done all of the checks, cleaned out carb, new plug, etc. No change.
Stripped the motor down to basics, just to check for internal wear and see if the governor teeth are still intact, no problems noted.
Replaced carb with new, no difference.
Mutimetered the coil, all ok. BUT remembered that from a previous problem, the low voltage from a multimeter won't show up any short circuits which cut the spark at higher voltages.
Replaced the coil, runs like a dream now.
As it was,a dead coil or burnt exhaust valve were the only two problems left that were possible culprits.
But turning it over by hand showed compression was fine.
Sanli is a Chinese brand, engine is some Honda clone I believe. Around a quarter of the price of a genuine Honda mower. Great for cheapskates such as myself!
Not popular/available in the states? Not represented on your list of makes.
Ron.
Welcome to the forum.
IF you have a problem with your Sanli it goes in either the Other Brands or Small Engine & Mower Repair with he latter having the most threads .
Sanli makes a lot of mowers for other brands so photos will help the USA members to identify a similar USA branded mower.
Please try to refrain from tacking a differernt problem on the bottom of an existing thread it just gets people confused ,
The techs all use the unread posts search so will see it but some will leave unknown brands for a few days to see if there is some one more familiar with that brand.
If you get no reply after a few days then reply to your own post with a line like "any takers " etc
