Papakevin
- Aug 4, 2022
- 9
After it had been sitting for a couple years, I put gas in it and it wouldn’t start. I removed the air cleaner, shot some starting fluid in and the motor would run briefly, then die. I figured there was an issue with the carb, likely gunked up from sitting.what was wrong with the old one? What prompted you to decide the carb was the cause of whatever the mower was doing?
With the replacement carb, it now runs, but at a very low speed and sputters when running. When put under load, it dies.
