Papakevin
Hello. I just replaced the carb on my Briggs and Stratton 500e edger. I also replaced the primer bulb, the air filter media, and I dumped out all of the old gas and filled it with new.
The unit now starts after three primer pumps, but sputters and eventually dies when put under load. Is there something special I should do to prime a new carb? What can I check next? FYI, there is no throttle adjustment on the unit. Thanks.
