This past spring, I had a Craftsman rider with the same problem come to my shop. I replaced both push rods, started it and it threw a rod in less than five seconds! When I tore down the engine, I found that there were two other push rods in the pan. The steel rod had made contact with the camshaft, bending it and cracking the camshaft bushing housings on both ends. Obtained a replacement engine from jackssmallengine and all is fine now. Any one who needs parts can pm me, I have both head assemblies, carb, flywheel and both pistons along with all of the plastic parts.
