Briggs and stratton 24hp vtwin vertical
raamw
I have a sears lawn tractor with the above described engine
Model 445677, type 0476Ei family 6Bsxs 7242vf 276480
It developed a loss of power, found it wasn't firing on one clylinder, removed valve cover. Both push tubes bent and displaced. No indication of valve piston contact nor bent valves. Checked other cylinder and it was OK.
I have no idea what caused this since I am unfamiliar with the internals of this engine. Do you have any ideas? schematics.\
I pulled the engine
I pulled the engine
That's the Intek OHV V-Twin, right?
********* Correction********
If it's the Intek V-Twin OHV the problem is the valve guides, not the seats. I have to remember not to post so early in the morning (before 10:00am). Usually the same source for the problem: overheating caused by lack of air flow over the cylinder. the real fix is to replace the cylinder head and gasket, but people have tried to repair the guides. A new cylinder head should be about $150 including the gasket.
If so, damaged valve seats are a fairly common problem, and usually caused by engine overheating due to air blockage around the cylinders. Sometimes a simple replacement of the valves is enough, but if there's damage to the cylinder it will cost $$$ for a new one. Some people have had luck repairing the valve seats.
Here's what B&S gas to say about it:
This failure usually occurs due to an overheating issue. Overheating is a cause of engine failure from an engine component material that has distorted beyond a specific yield point. The yield point is the limit of a material at which it can be exposed to heat or mechanical stress and still return to its original size and chemical composition. Overheating occurs from causes such as a lean air-fuel mixture, use of improper fuels, dirt and/or debris buildup on cooling fins, damaged cooling system components, reduction in cooling air, over speeding, or an improper engine enclosure.
Valve seat inserts are installed in the cylinder block using a press fit. A press fit is a method of attaching two mating components where one component is pressed into a machined hole having a slightly smaller diameter than the component inserted. Valve seat inserts are commonly .003 - .005 larger than the machined hole in the cylinder block. The pressed fit retains the valve seat insert in position with a constant force. This force is necessary as small engine have significant responses to heat generated in the combustion process. If the cylinder block expands past the yield point, the force is not present to keep the valve seat in place.
In some cases the valve seat can be peened back into place. However, there is no guarantee this type of repair will add significantly to the engine's life.
Would replacing the complete clylinder head cure the problem, I see that B&S sells a replacement cylinder part number 693999, I am assuming it would be complete with all parts including valves valve springs etc just bolt on
Correct. The cylinder head will come with a head gasket and all internal parts. Should be somewhere around $150.
have same mower and pulled both heads for replacement
Got new heads
now can not figure out if the steel rod goes top or bottm??????
This past spring, I had a Craftsman rider with the same problem come to my shop. I replaced both push rods, started it and it threw a rod in less than five seconds! When I tore down the engine, I found that there were two other push rods in the pan. The steel rod had made contact with the camshaft, bending it and cracking the camshaft bushing housings on both ends. Obtained a replacement engine from jackssmallengine and all is fine now. Any one who needs parts can pm me, I have both head assemblies, carb, flywheel and both pistons along with all of the plastic parts.
I purchased a new cylinder head and new push rods and put it back together resetting the valves and it has been running fine.
Which rod goes where steel rod alumimun Which goes on top??????
