DrewVIII
- Aug 4, 2022
- 2
I have an issue that may have been covered in another thread, but I am hoping you all can either point me there or just help out here.
This engine is in a Scotts/John Deere lawn mower. After running for about 45 minutes it starts to run rough and the RPMs start to ebb and flow. Eventually it starts shaking and dies. Initially, it would run if I kept the choke on and I could at least get it back to the garage. That no longer works. However, if I let it sit for an hour or so it starts up fine and runs smoothly.
I thought it must be a carburetor because this is a used tractor. I took that off and it was in good shape. I cleaned what little grime there was and put it back on. It ran fine for one mowing and now its back to where it was.
I am new to this kind of repair. What should be my next attempt to fix this? I dont think the gas is bad. It was empty when I got it and have been using gas from the same can. It mowed the lawn just fine 5 times. The fuel filter looks good.
Any help would be much appreciated! Educate me!
Thanks in advance!
Thanks in advance!
