Briggs and Stratton 20 Hp Major Failure - Never Seen Like This
7394
  • / Briggs and Stratton 20 Hp Major Failure - Never Seen Like This
OK, I missed "last fall" don't have a cow man..
xavier56
Sorry if you took it wrong - was just saying the oil would be on the bottom by now.
Also still wondering what a good replacement Engine to replace this one.
Do not have any hopes bringing this one back to life.
Thanks
Tinkerer200
31 series B&S will work fine and be a direct replacement except may have to check alternator which will interchange if necessary. Be a lot easier found if you are looking for a used one.
Walt Conner
xavier56
Used not finding much out there.
I can get a New Briggs 33R877-0032 for like $515 or 33S877-0019-G1 for like $567
I think either one will work.
Yes ????
Thanks
Any engine with the same output shaft diameter and length will fit.
Using the same brand & series just makes it easier as it is pull out drop in plug up & you are good to go.
Check out the surplus engine suppliers and the surplus centre for available engines at big discounts.
If you go with another Briggs the only thing to watch is the alternator output.
However all Briggs alternators interchange so you might need to swap the stator And perhaps the flywheel ( cant swap between single & twin flywheels ).
A twin will be better than a single just check the dimensions so it will fit.
Other things like exhausts are a bit more difficult as they are part of the mower & not the engine.
Lots of engines at this time of year
I like to buy "pulls" because they are scratched from being fitted so go for a lot less.
A strait engine swap is about a 2 to 3 hour job.
Just make sure you thread the mounting bolt holes before you place the engine otherwise you will need some one to hold the engine and push down on it while you try to force the self tappers in from underneath.
Romore
The direct replacement is model 33M777-3036-G5 which is plug and play, you will need to use your muffler. It should be less than 6 bills. You could also short block but that will be more expensive than a complete engine.
