Hello All
I have a Snapper Lawn Tractor that was purchase in May of 2013 with a 20 Hp Briggs and Stratton Engine. Model 33M677 0110 G5 .
The Tractor has 150 Hours on the Engine Maximum. Every year the oil has been changed with new oil filter installed. So it has been well maintained. The Engine Ran fine with no issues all these years.
Then last fall the Engine had a Major Failure. It was running fine cutting lawn then like Sputtered and LOUD BANG. It Stopped. After lifting the hood it was seen the Whole Rear of Engine was Blown wide open. I mean the Whole Back at least 1” gap of Metal all the way across the whole rear of Engine. There where pieces of metal all over this area.
Looking at it you would think the Rod had failed somehow – the spark-plug was removed and it turns over by hand and still has compression so The Rod is not Broken as one would think.
The Engine is still installed in the tractor so it has not been taken apart yet to see what caused the failure.
Has anyone else seen this type of Briggs Failure and What is the cause?
Also does anyone know a Good Model Replacement for this Engine.
Thank you
Thank you
