- May 6, 2010
- Threads
- 51
- 11,398
I use pro parts direct.com, they have the ACR but need to call for avaliabilty .... I know cub cadet (kohler) makes the ACR for their cam.
I AM JUST GOING OFF OF WHAT I HAVE SEEN ON MOST LAWNMOWERS Cam wise.
the one that they list on their website for the ACR is for the Courage single. I replaced one of those this summer, and then had to go back in and replace the cam gear because evidently it was slightly warped causing the ACR to hang up and not work sometimes. The compression release on the camshaft in this guys case is pushed through the cam gear and then pressed into the rotating counterweight with a halfmoon part of that same pin that acts as the compression release. There are no rivets that hold it attached.
The weight gets broken around were the pin in halfmoon shaped, and ends up in about 4-5 pieces, the rotating pin normally will be 2-3 pieces and then the spring is found damaged sometimes and not others.
pull up a picture of the briggs 793880 camshaft and you will see what cam he has in this engine that is possibly the cause of his start issues.
