I must have reset the valves 30 times to no avail and as a last resort decided to try to jump start the mower with my car battery. Sure enough the mower started right up, so my problem has been the battery all along... I had the battery tested twice at O'reilly auto and both time was told it was good. And I charged it quite a few times while adjusting the valves as well and had it tested after charging.
Just thought I would post what worked for me in case it helps someone else, because the valves are fairly easy to adjust. If you adjust them a few times to no avail, make sure the mower uses a 12 volt battery ( from what I understand about all modern mowers do ). Then see if it will turn over normally with a battery that you know for a fact is good.
P.S. - I'm not expert at repairing mowers but do most repairs on my cars. I've had a good dozen or more car batteries tested at auto parts stores - this is the first one I've had test goot that isn't good lol.
Thanks for the help guys.
