I picked up this 8hp industrial plus Briggs engine as a replacement for my brush mower. Good running engine. When swapping it out, found this one has a 1-1/8" shaft size, and my 1" pulleys won't swap over.
Does anybody know what these were used for, or if these are in demand? First one I have seen this size on a small motor. Also, are the cranks interchangeable with the older engines? I'm debating on tearing into it and either swapping the crank out for a 1" I have, or milling down the existing one to fit. Just don't want to do so if this is a "special" engine.
Model 196402, Type 1165 E1
Side note, the engine I could borrow the crank & parts from is a 190402 type 6144 01
