I have a Briggs 7.8hp engine on a Sears power washer that was purchased new, run about 4 hours and suddenly won't keep running after starting. I start it, the engine runs for 6-10 seconds and quits. It will immediately restart but then quits and on and on. I have removed, cleaned and reinstalled the carb. Cleaned the tank and added new fuel. The fuel line is clear. I removed the gas cap suspecting a vacuum lock but it didn't help. I know engine has a low oil pressure switch and wonder if this could be it. Or is there some other module that could cause this type of failure ? Any suggestion would be appreciated.
Richard
Richard
