Scott, the muffler looks almost straight... and there is a plate between it and the block (the plate the come in front to lock bolts with bending tabs).
But on the part chart the gasket between the plate and the block is missing. And there is some remnants on this plate, exactly.
For the carburetor double gasket, looks like they a factory but I find that strange too ! again carburetors mounting screws looks new. I'll try to replace with only one...
Boudreaux In Eunice La ha yes it's for the cubic inches ! Nice explanation thanks ! I did not think at this at all, cubic inches does not speak to me... don't have the habit of this unit. For me it's a 206cc, but its a 12.6cu in too
This has probably something to do in the model serie naming : 130000
Thanks for the information for setting the governor too ! Yes I see this tang, ok I understood. It's probably while I turned the thumb nut it was only making small changes !
The last mystery thing is this tang has no mark on it, so never modified I think. But while releasing spring tension with bending it I can lower RPM. Yes I checked the posted diagram and have stored the L-Head manual, it's quite handy
Merci mon ami !
Fish, I posted clearances a few post ago, but here what I measured :
Exhaust between 0.10 and 0.15mm (can put 0.10mm feeler gauge but not the 0.15)
Intake almost 0.15mm (gauge is tight, should be more free)
So I have to increase EX to 0.25, and do a small touch on intake. From what I know EX is more prone to "move", so it make sense ?
By the way I use two feeler gauge sets, one good but with low resolution (0.10mm) and one cheap with more feelers, and they both match. Of course I check that with piston at TDC, on compression stroke.
