Mkala
- Jan 5, 2019
- 140
Oki... But I don't have seat cutters and I dont plan to buy some, I checked and they are way too expensive, like 300-400$ !
If I only buy a new valve this make a difference without touching the seat ?
Yes valve guides are within specs, intake is perfect and exhaust as a bit of play - but the valve itself is also a bit worn. Detailed measurement above in post #7
Intake guide is really nice, I had to file the valve stem (where the keeper retain it) to remove it without scratching the guide (its only aluminum in the block, bushing is available only for repair on intake). Intake valve has no wear too on the stem, was very surprised to had so much wear on the valve face.
