motormonkey
- Nov 1, 2014
- 11
I don't feel that .003 is too great a clearance, but I would like to kno how you got that. You should have measured the valve stem with a mic at multiple places in the travel area. There should be no more than .001 difference in any of the measurements. You the measure the valve guide at the top, center and bottom with a small hole guage and mic. Again you should have no more than .001 difference between any measurements. The difference between the valve stem measurement and the valve guide measurement is your clearance.
Second, you never said what was the cause of the valve sticking in the first place and what corrective action you took. If the valve was bent or the guide tapered, you are spending a lot of time and effort for nothing.
Rivet, you are right.... I didn't say the cause of the valve sticking did i?
I know this much.. the issue is in the head... the valve wasn't bent, and the tappets aren't bent either... the cam.. showed some wear... I will try to get a few pictures tomorrow of the pieces... I am going to tear it down again....
I DID clean it up thoroughly(Head and piston head/block also the cylinder wall is spotless.)... sanding the valve stems lightly and lubing them before putting them back in.. after that, they moved beautifully in the valve guide.
This is a unique situation as I am currently traveling in a third world country... and I cannot get replacement parts here can't order them in either... international shipment costs like $100 bucks just to get a letter.
I was lucky to find a business that custom makes gaskets so I took the old headgasket and they made me a new one.
Update on the problem: I unstuck the valve via the valve spring access door and got the mower to run horribly for 30 seconds...
then to restart it I had to continue pulling the rope to kind of Help it stay running.. (it was running very slowly, obviously slow enough for me to pull the recoil along with it every 3 seconds to keep it running)
I guess it is also possible I got the valve tappets reversed... though that wouldn't explain the valve sticking in the head.. the only thing I can think of is the head is warped... and something happens with the expansion of the metal(perhaps exaggerating the warp in the valve guide when it heats up...?
this is frustrating trying to get it diagnosed correctly.. again, i'll try to take some pictures perhaps tomorrow maybe that will lead to some insight.
thanks everyone for your replies in the discussion.
