Briggs 4 cycle engin
wally3907
what would cause oil to collect in:thumbsup: the air filter compartment.
reynoldston
Crank case pressure build up. ( Plugged vents, worn out piston rings, bad head gasket )
Vervepipes
If the engine was tilted the wrong way it would cause oil to pool in the filter box as well.
exotion
Old oil becomes very "watery" thickness and running like this makes oil splash around more then normal and even the smallest tilt can make oil go where it's supposed to.
reynoldston
Craftsman?? small push mower? large rider? Steep hills? Flat Ground? Are you tilling it? Do you maintain this mower with schedule oil changes? If not I would say engine problems not a normal thing to happen..
