Re: Briggs 28Q700 - Flywheel issues.... NO JOY!
Well! I should not have spoke too soon after only running the mower a few minutes last night. (After valve job).
Things are NOT well.
Tonight:
-Put in new air filter....put shrouds back on....
Fired it up. The starter had trouble cranking,...it engaged....and spun....but very hesitantly....Upon re-tries it started. But had to crank awhile!!
*Note: When starting you must have the brake depressed.
When it would 'catch' and start running....it ran rough....10-30seconds...when I took my foot off the brake it died.,....and backfired a big spark
Started realizing it would die everytime after I let off the brake.
On more start attempts I noticed that keeping the key in the "start" position while waiting for the engine to catch....with the starter running: The + wire on the bat was smoking and melting the rubber sleeve around the + terminal
Finally I decided to start it, keep my foot on the brake (since for SOME reason taking my foot off the brake causes the engine to stop)....so I ran it like that for awhile (maybe 1 minute)...before I noticed an orange glow "pulsing", "emitting" from the muffler.
SO I shut it down immediately. The muffler area was HOT....TOO HOT.
So I am at a loss.
- Something is up with the safety switch on the foot brake. I put in a new solenoid. There were 2 fin clips....blue wire and white wire. I did not think it mattered which wire went to which fin....maybe it does?
- Could I have screwed up the valve adjusment?
- Again, the starter motor has trouble turning the flywheel....it DOES,...but only have several start attempts.
- Pulled plug....nothing crazy...looked fine.
- Brand new hi amp cold crank battery. New starter motor. New ring gear. New solenoid. New ignition switch. New fuel filter. New air filter. New plug. Checked and gapped properly.
Thoughts?
