THANKS! Chance!
So....taking your advice,...and 1 whack! And it popped right off.
There were no thrown magnets,....I cleaned it up....put on the new ring gear...put it back on....and....no joy.
Here is what it is doing:
1 - Starter motor 'tries' to start it,....but only briefly...it spins up, engages the ring gear and rotates the engine maybe 1-1.5 turns before stopping,...essentially acting like it only has enough 'oomph' to turn it a little bit. note:* I kept starter motor gear that came with starter...I did not replace with starter motor gear that came with ring gear. They have same #of teeth,...I will say though that they are slightly different in 'tooth shape'.....not sure if that could be source of issue? Doubt it.
- With meter, the wire to starter is supplying 12.5v when attempting to start. So solenoid is good.
- Battery has fresh charge and shows 12.5v as well......after awhile of trying to start it...battery was at 11.9v
2 - After the initial attempts (maybe 4-5times) of trying to start it,...eventually the starter would engage the ring gear but wouldnt turn the flywheel at all.......
3 - When the flywheel would turn, in the initial attempts to start....the engine made NO sound like it was trying to combust or start.
- New plug
- New fuel filter
So...I guess now I need to start going down the long list of diagnosing the whole spark,fuel,compression thing. A lot to learn,....will be spending a good bit of time on google today!
I know good info exists on testing spark,....carbs...etc..etc.
One thing I read about was trying to start the mower without the plug in and see if it rotates the flywheel. I am not sure what doing this proves,......thoughts?
Any other, overall thoughts? Tips or tricks?
FYI - The mower came with the house, and was definitely not maintained well. It ran fine for a few months,....then this all sorta happened at once. Wouldnt start....solenoid/starter motor followed quickly.
- New plug
- New fuel filter
