Briggs 27hp engine wont idle down
Crandall312
Bought a used bad boy with a briggs 27 hp intek that had a broken governor gear. I replaced the gear and adjusted the governor like the manual says, but it still runs away when you start it. The throttle cable works and the throttle plate on carb moves freely. The governor arm moves like normal when engine is off, but when started it wont move.
Model: 44q777
Type: 5148g5
Code: 130318yg
Sorry to say you have either hooked up the governor wrong, or the pin inside the engine dropped out while you were assembleing it.
Happens all the time
