shiftsuper175607
- Sep 11, 2013
- 1,000
I have a 22hp intek with about 650 hours on it. It wasn't running right. I toke it in to John Deere and they said the rods were bent. They replaced them and the new ones bent right away. They said it may be cam. I tore motor apart and cam looks fine to me. It's not bent and nothing looks damaged. When I move the things the rod connects to(rocker, valve) they don't give more resistance than I think there should be. I did clean the carb out a few months before this. One of the plugs looks dirtier than the other. I really don't know what I'm doing if that's not obvious any help would be appreciated.
If the valves were not adjusted right when the new push rods were installed....maybe they got loose...slipped position and were bent.
You assume the installer knew what he was doing...
Both rods bent seems odd.
