GrantM
- May 27, 2023
- 1
- 4
I have a Craftsman riding mower with a Briggs 18.5hp Intek OHV. I mowed my lawn and then shut the mower off. I came back a couple minutes later, tried to start the mower, but it would not start and cranked very fast. I did a compression test, and it had 0psi of compression. Unsure of the problem, I did my research, and found out that the cam could be bad. Ordered new cam, removed engine, replaced cam, lined up timing marks on shaft and cam, and put it all back together. I then reset the valve lash to (in) .004 and (ex) .006. No difference. I removed the flywheel, inspected the flywheel key, which was NOT sheared, and put it all back together. I replaced the spark plug, no difference. I reset the magneto and flywheel gap, thinking maybe the spark was weak, no difference. I then inspected the valve again and found that the exhaust valve looked slightly open. I removed the head, and sure enough, the valve seat was ajar and the valve wasn’t closing fully, causing the no compression. I removed the valve, and carefully tapped the valve seat back into place, and it looked secure. I reinstalled the valve, which now sealed excellently, and put the head back on. Reset valve lash, and… it runs, but terribly. Runs only on half to full throttle, and shuts off after short time. When trying to start it still backfires through intake and exhaust if the throttle is in idle position. I did a compression test, and it has 130psi. I then cleaned the carb, removing the jets and running a guitar string through them, and spraying carb cleaner. Reinstalled carb, no difference. Ordered new carb, installed, no difference. It is still backfiring through the intake and exhaust. Sometimes there is ever flames through the intake. Throttle linkage working properly. I am utterly stumped, and ready to blow up this mower. Please help.
