Daquiri_briggs
- Feb 15, 2016
- 50
I think I may have done the opposite of what you told me, watch these videos in order and let me know? I tried starting it and it sounded kind of weird, so I wanted to check again before I cranked it up.
The reason I think I done it the opposite way is because, the rod went right when I messed with the lever on the carb. I then put the throttle to full throttle, turned the screw to the right and tightened it up.
Now, nothing moves but that middle piece with the big screw when I move the throttle and the lever on the carb remains super tight away from that idle screw.
1.
https://www.dropbox.com/s/uqv39zl8jd868v6/Video Mar 10, 6 49 33 PM.mov?dl=0
2.
https://www.dropbox.com/s/susv5b83fe6gelp/Video Mar 10, 6 53 09 PM.mov?dl=0
EDIT - It wont start now and it sounds real bad when I try to turn it over...
Another Edit - I put the throttle at full go, turned the screw to the left as far as it would go and then it ran a lot better, but still didnt quite like to much action. A slight hill and it would slow down tons
1.
2.
