Tinkerer200
If you search you may find a picture of the chewed up pushrod from my Intek in this forum. The part that went down the flea hole into the digestive track was broken like yours, but also had a lot of nibble marks where the gear was tasting before biting. :laughing:
While this does happen occasionally most of the time the push rod is simply lying there waiting for someone to invent a way to fish it out. I tried. I have also thought of putting a screen in the drain hole to prevent push rod from going down as a preventive measure.
Walt Conner
