darrinster
- Sep 9, 2015
- 24
- 111
Model 407777 0128 e1
Broken/bent rods on the #1 cylinder. The exhaust rod was almost eaten. I pulled it out but something was clamping down on it. Picture of the rods.
Engine does spin with no knock. I tried running it on the one cylinder but it would not fire. Was getting spark. Valve guides have not moved.
I noticed really dark oil sludge in the valve cover. I'm guessing the oil was never changed.
Do you guys think the engine is worth saving? Anything else I should check?
